May 25, 2019, 04:12:46 am
Author Topic: CAS voltage not the same  (Read 1786 times)
Offline bqc
Re: CAS voltage not the same
« Reply #15 on: September 14, 2016, 07:48:53 pm »
I checked the jumpers for the 8 ohm secondary and they are correct. There are no tabs touching ground. I measured the secondary winding to be 0.6 ohm for the left channel and 1.1 ohm for the right. Is that significant?
The primary winding for the left is 218 Ohm and 215 for the right.
Shall I try to rewire the secondaries as 4 ohm and see if they work any better?
If the output transformer is bad, what is the spec for this transformer and do you know of a compatible transformer model that I can order from places like Digikey and mouser etc...
« Reply #16 on: September 15, 2016, 05:07:29 am »
The secondary measurements are a bit of a concern - if they are accurate. It is pretty difficult to get good readings of resistances down around 0 to 1 ohm because oxidation or other contaminants on the tips of the test probes or the test point can throw off the reading. I usually burnish the tip of the probe against the test point to try to get through any schmutz.
If you continue to get those different readings with the probe tip and test point making excellent contact it's time to look very closely at your secondary connections and speaker binding post connections. The likelihood of the output transformer being defective is very low. I can't recall a bad output transformer from our winder in the past 15 years. So it would be prudent to inspect everything connecting to the transformer secondary very carefully before making that judgment.
Offline bqc
« Reply #17 on: September 15, 2016, 11:14:55 am »
I made sure the tip had good contact. It started out to be 3 ohms or so and slowly settled to the values reported. What is the expected normal range for the 8 ohm secondaries?
« Reply #18 on: September 16, 2016, 06:28:42 pm »
Normal DC resistance across the secondaries will be so low that it's difficult to measure reliably.
It sure would be helpful to see photos of the build, if at all possible, especially of the output transformers and speaker posts.
Offline bqc
« Reply #19 on: September 18, 2016, 12:58:43 pm »
here are the pictures.
I also rewire the left channel secondary as 16 Ohm but the voltage measurements are the same as before.
« Reply #20 on: September 19, 2016, 05:31:27 am »
How is your supply of clip leads?
Offline bqc
« Reply #21 on: September 19, 2016, 06:37:42 pm »
not too many, why, what do you have in mind
« Reply #22 on: September 23, 2016, 06:10:12 pm »
I'm thinking that you could remove the secondary wires from both output transformers (just take all of them off, the secondary wires are the jumpers and the twisted pair that heads back to the speaker posts).
Next, recheck your AC voltage measurements.  If they are still off, power down the amp, then remove the red and black wires at output transformer terminals 5 and 10 on both transformers.  Take a pair of clip leads and clip lead each output transformer into the other channel, then repeat the measurements.
Just as a reminder, the AC voltage measurements should be taken at terminals 5 and 11.
