May 20, 2019, 11:37:10 am
Author Topic: seduction pre amp quit working  (Read 1188 times)
Offline leland
« on: September 08, 2015, 09:04:05 am »
my seduction quit working and I can't find my cd to test this can anyone help with this
Offline galyons
  • Geary Lyons SF East Bay Area
Re: seduction pre amp quit working
« Reply #1 on: September 08, 2015, 09:16:37 am »
Hello,
You will need to be more definitive as to the problem then "quit working".  What is not working? Is it plugged in, fuse blown, getting power to the transformer?  Are the tube filaments lighting?
Get out your DMM and run the voltage checks:
Seduction Voltage Checks
Terminal          Voltage
6                6.5VDC
7                0VDC
9                6.0VDC
10                0VDC
11               0VDC
12              135VDC
14                0VDC
15                148VDC
16                0VDC
20                0VDC
25                160VDC
26,36             0VDC
27,37           70VDC
28,38            0VDC
29 ,39             70VDC
30 ,40            70VDC
34,44             135VDC
35 ,45             0VDC
A1,B1            70VDC
A2,B2             0VDC
A3,B3             1.6VDC
A4,B4             0VDC
A5,B5             6.0VDC
A6,B6                  70VDC
A7,B7                 0VDC
A8,B8                1.6VDC
A9,B9               0VDC
Let us know the results.
Cheers,
Geary
VPI TNT IV/JMW12.7i/FR1 MkII Soundsmith retip >Eros TH+ Otari MX5050 IIIB2 > Eros + ANK Dac2.1 > BeePre >Paramount 300B 7N7 > EV Sentry IV-A
Crack 7N7 > Sennheiser HD650 & AKG K240 Sextetts
Offline leland
« Reply #2 on: September 08, 2015, 11:24:00 am »
terminal      voltage
6                   9.4
7                    0
9                   5.46
10                  0
11                  0
12                 178
14                  0
15                 177
16                   0
20                   0
25                  178
26,36             these two bounce all over the place and the L.E.D.'s come on when i check here
27,37   starts high then goes down to 73.1 when LED's come on ,178 led's dont come on when i check here
28,38               0
29,39            177
30,40             bounces around a lot 70 and up
34,44             178
35,45               0
a1,b1              68.6, bounces around 90's up to low 100's one led blinks
a2,b2            .03, bounces around 1
a3,b3             1.49
a4,b4             9.6,9.61   led's have gone out at this point
a5,b5             10.4
a6,b6              178
a7,b7              0
a8,b8              .003,.007
a9,b9              0
at this point nothing seams to turn the leds back on
« Reply #3 on: September 08, 2015, 12:18:06 pm »
You have a flaky solder joint making an intermittent connection.
Offline leland
« Reply #4 on: September 08, 2015, 03:02:58 pm »
I can no longer get the leds to light any suggestions as to whare to start looking for this bad solder i dont have a schematic for this
« Reply #5 on: September 08, 2015, 03:32:05 pm »
Just reflow every joint. It will take all of ten minutes.
