May 25, 2019, 04:15:34 am
Author Topic: Stereomour manual corrections  (Read 5384 times)
« on: February 02, 2011, 01:42:53 pm »
This is for manuals before the 6-30-11 version:
On page 45, under 6,3V heater wiring:
Where it says "Connect the red wire to power transformer terminal 12 at one end and pin B5 of the nine pin socket. Solder all four terminals."
it should read "Connect the red wire to power transformer terminal 15 at one end and pin B5 of the nine pin socket. Solder all four terminals."
The photo is correct.
For manuals before the 10-21-11 version
On page 32 it should mention that the two larger holes in the four pin socket should go near the hum balance potentiometer
On page 61 the first paragraph should say strip 1/2" of the cover off, not 1-1/2".
On page 67 "Attach the other from 2U to the
« Last Edit: October 21, 2011, 09:41:49 am by Doc B. »
Re: Stereomour manual corrections
« Reply #1 on: November 21, 2011, 04:15:11 pm »
Also, where it says on p.45 "6,3V heater wiring", that should be 12.6v heater wiring.
Offline smithanh
Stereomour manual
« Reply #2 on: March 05, 2012, 01:57:34 pm »
The CD that came with my Stereomour manual can't be read by my computer.  Is there a PDF download available?
Andy Smith
Offline azrockitman
« Reply #3 on: June 25, 2013, 07:32:23 pm »
The photo on page 42, depicting the underside of the chassis, with the appropriate red numbers beside many connections:
THe output transformer on the right shows "1,2,3,4,5" on the top side of that transformer.  Mine are just the opposite  ("6,7,8,9,10" are visible)
Is that an incorrect photo?  I hope?
Esoteric DV-50, Technics SL1200-M3D, B&K Phono 10 Preamp, Sumiko Blue Point Special Evo III, Bottlehead Stereomour, Orca's
« Reply #4 on: June 25, 2013, 07:40:38 pm »
You may have a transformer that was slipped into the channel frame upside down.
You'll want to trust the numbers on the transformer(s) you have in your hands, not the photos in the manual.  (Good catch by the way!)
