June 18, 2019, 08:01:53 am
Author Topic: Eros 2 Help  (Read 135 times)
Offline adeep42
Eros 2 Help
« on: June 10, 2019, 03:52:16 am »
Working on my Eros2. Completed the Power Supply. All voltage tests on the money. Moved forward to Shunt Regulator.
Got to voltage check and voltages were way off. As I was getting ready to make note of the readings, the resistor at AR4 sparked and fried itself.
Thanks in advance for the help.
Alan
« Last Edit: June 10, 2019, 04:23:58 am by adeep42 »
Crack with Speedball
Eros
VPI Prime
Ortofon Cadenza Bronze
Bob's Devices VPI SUT
Phoenix Eagle PSU & Tach
Cambridge 752BD
Apple Airport Express
PrimaLuna Prologue Pre-amp
PrimaLuna Prologue Amps(as mono-blocks)
Martin Logan Summit X's
Re: Eros 2 Help
« Reply #1 on: June 10, 2019, 04:05:24 am »
Would it be possible to upload larger images?
Offline adeep42
Re: Eros 2 Help
« Reply #2 on: June 10, 2019, 04:27:25 am »
Hi Paul,        Hope these work could go higher if your blog system will accept them.
Eros
VPI Prime
Cambridge 752BD
Re: Eros 2 Help
« Reply #3 on: June 10, 2019, 05:02:19 am »
You have RC and R4 switched.
You can try replacing those parts and firing it up, but be aware that you may need to replace the whole board.
Offline adeep42
Re: Eros 2 Help
« Reply #4 on: June 10, 2019, 05:12:53 am »
Thank you Paul. Not sure if I'll have time to remove the offending resistors today and then assess the board. Will respond after. One way or another I'll need some resistors (at least one).
Eros
VPI Prime
Cambridge 752BD
Re: Eros 2 Help
« Reply #5 on: June 10, 2019, 05:21:03 am »
You can contact replacementparts(at)bottlehead(doht)com to get the ball rolling on that.
Offline adeep42
Re: Eros 2 Help
« Reply #6 on: June 10, 2019, 05:48:11 am »
Thanks Paul,
I've just done that.
Regards,
Alan
Eros
VPI Prime
Cambridge 752BD
Offline adeep42
Re: Eros 2 Help
« Reply #7 on: June 14, 2019, 10:45:16 am »
Hi Paul,
Looks like I need a new board. If the solder pads were not wrecked before, I wrecked them removing the bad resistors. I'll write to Eileen at replacement parts.  Please coordinate with her so that I get every thing I need particularly those parts that you think might not survive being removed and replanting.
Thanks in advance,
Alan
Eros
VPI Prime
Cambridge 752BD
