May 20, 2019, 11:41:47 am
Author Topic: FC-1 Choke Pin-out  (Read 171 times)
Offline korneluk
FC-1 Choke Pin-out
« on: January 24, 2019, 02:32:50 pm »
Given the assembly pin-out below, what is the connection for the FC-1 choke in common-mode?
upper bobbin 10-9-8-7-6
lower bobbin 5-4-3-2-1
Re: FC-1 Choke Pin-out
« Reply #1 on: January 24, 2019, 04:00:45 pm »
It's probably easiest to just show snippets from the old Paramount manual.
The "input" side is always the left most top and bottom terminal in the photos I attached.
« Reply #2 on: January 24, 2019, 08:21:43 pm »
Those photos from the manual are differential mode for the main inductance - only the leakage inductance is in common mode with that connection.
It's late so I won't try to describe the connections. I will show the spec sheet instead, and answer questions if necessary tomorrow  :^)
