May 24, 2019, 12:16:38 pm
Author Topic: Reading 208V at 40, 43 and 46 - spec'ed for 213V [resolved]  (Read 193 times)
Offline Deke609
« on: December 08, 2018, 11:23:44 am »
Except for 40, 43 and 46, all my voltages are within 1% of the specified value - but always slightly on the low side.
But 40, 43 and 46 (specified as 213V) read as 208V - a little less than 2.5% low.
Is this a problem, and if so, is there a typical culprit?
If it's a problem, I'd like to troubleshoot it myself and only start posting pics and taking additional measurements if I fail to fix it.
many thanks in advance,
Derek
Edit: I inserted it into my system and fired it up and it sounds superb. So I'm guessing that if the above is a problem , it is a very tiny one.
« Last Edit: December 09, 2018, 02:08:38 pm by Paul Birkeland »
Derek
______
Roon Intel NUC ->  Yggdrasil DAC -> BeePre (w/ BeeQuiet and JJs)  -> Stereomour IIs (2A3 and 45 Conversion - both fully upgraded)  -> Audeze LCD4
Re: Reading 208V at 40, 43 and 46 - spec'ed for 213V
« Reply #1 on: December 08, 2018, 03:11:07 pm »
No problem - that's the voltage before the regulator. The regulator exists to isolate the signal circuit from the raw power supply voltage, which does fluctuate with the power line voltage.
Offline Deke609
« Reply #2 on: December 09, 2018, 12:15:48 am »
Many thanks PJ.
Derek
______
