February 18, 2019, 10:39:52 am
Author Topic: Voltage issue on Terminal 6 and 10 [resolved]  (Read 369 times)
Offline BeoRski
« on: December 04, 2018, 11:09:40 pm »
Hello,
Just finished assembling a Crack kit and everything checks out good except for Terminals 6 and 10 which both read ˜100 Volts. Any ideas?
Best Regards
-G
« Last Edit: January 07, 2019, 07:54:36 am by Paul Birkeland »
Re: Voltage issue on Terminal 6 and 10
« Reply #1 on: December 05, 2018, 04:53:11 am »
Can you post photos of your build?  Please do not attempt to use this amplifier in its current state.
Offline BeoRski
« Reply #2 on: December 05, 2018, 10:23:08 pm »
Hi PB,
Thanks for responding. Here's my build.
Best Regards,
-G
« Reply #3 on: December 06, 2018, 06:26:16 am »
Your headphone jack looks to be improperly wired.
Offline Deluk
« Reply #4 on: December 06, 2018, 07:51:07 am »
The inputs don't appear to have the solid copper wire link for the earth. The silver wire is rather confusing as there looks to be 2 wires in places where my crack only has one, especially at the headphone jack as PB says. Why did you use this wire? All my wiring is black red and white as supplied by BH. No green or silver.
Offline BeoRski
« Reply #5 on: December 06, 2018, 10:51:23 am »
All leads have been properly tested but I might have missed something. I will rewire the input/output section and report back how it goes. Using these wires for aesthetics but will try using the solid wires to make it less confusing to look at. Thanks for the help.
« Reply #6 on: December 07, 2018, 05:50:48 am »
Yes, you missed some connections on your headphone jack.
Offline BeoRski
« Reply #7 on: January 06, 2019, 11:44:47 pm »
I rewired and used the solid wires and also reviewed everything. Still the same readings.
Offline diynewbie
« Reply #8 on: January 07, 2019, 01:59:25 am »
I'd check the manual for headphone jack.  In the previous version of the crack the inner connections all went to lower outside ground.  So in the new version of the wiring I would expect all of the outer lugs on the jack to be joined together.  I could be wrong, but check the manual carefully.
Offline Deke609
« Reply #9 on: January 07, 2019, 04:38:50 am »
Ditto. In my Crack 1.1 manual the outer lugs of the jack are wired together.  From your pics, it looks like these connections are missing. See attached pic  with circled orange line indicating where outer lugs should be wired together according to the 1.1 version of the manual.
Very nice looking build, by the way!
Derek
Derek
Roon Intel NUC ->  Yggdrasil DAC -> BeePre (w/ BeeQuiet and JJs) -> Stereomour II (fully upgraded w/ JJs and Mullards) -> Audeze LCD4
Offline BeoRski
« Reply #10 on: January 07, 2019, 06:11:01 am »
I just reviewed the manual on a computer and you are correct. Gosh I need to have my eyes checked. The illustration isn’t clear on the printout. Thank you. I will fix it tomorrow.
Quote
Derek
Thanks! I hope it will work tomorrow so I can proceed with the Speedball. ^_^
- G
Offline BeoRski
« Reply #11 on: January 07, 2019, 06:12:13 am »
Thanks! Reviewed the manual on a computer and you guys are right. I missed that one.
Offline BeoRski
Re: Voltage issue on Terminal 6 and 10 [resolved]
« Reply #12 on: January 07, 2019, 06:43:48 pm »
That did it... thank you for all your help!
1 - 82v
2 - 171v
3 - 0v
4 - 171v
5 - 95v
6 - 0v
7 - 107v
8 - 0v
9 - 114v
10 - 0v
« Last Edit: January 07, 2019, 07:02:37 pm by BeoRski »
