May 24, 2019, 12:20:26 pm
Author Topic: Loose 4-pin socket - cause for concern?  (Read 225 times)
Offline Deke609
« on: December 02, 2018, 04:43:43 pm »
Just started assembling my newly arrived BeePre. One of the 4-pin tube sockets was not tightly seated in its retaining bracket and could be popped out.  When tightly bolted to the chassis, the socket had about 1 mm of up-down and side-to-side play. So I removed it and did my best to crimp the bracket to the socket. It seems tight-ish now, but doesn't look as secure as the other one which came tightly seated in its bracket.
Should I replace it? I'm really only concerned about the possibility of the socket vibrating and passing the vibrations on to the tube.
Many thanks in advance,
Derek
Derek
______
Roon Intel NUC ->  Yggdrasil DAC -> BeePre (w/ BeeQuiet and JJs)  -> Stereomour IIs (2A3 and 45 Conversion - both fully upgraded)  -> Audeze LCD4
Re: Loose 4-pin socket - cause for concern?
« Reply #1 on: December 03, 2018, 04:55:21 am »
A drop or two of super glue will keep the socket from moving around in its bracket, but this is otherwise not concerning.
Offline Deke609
« Reply #2 on: December 03, 2018, 05:49:33 am »
Excellent idea. Thanks PB.
Derek
______
