March 24, 2019, 06:16:04 am
Author Topic: Using a SUT with a Reduction + Integration  (Read 346 times)
Offline audiomaniac
  • No hill too steep, no ditch too deep!
« on: August 20, 2018, 07:20:35 pm »
I've been enjoying my Reduction + Integration for a while now with a MM cartridge. I'm thinking about trying a low to medium output MC cartridge and was wondering if there is anything I should look out for in matching a SUT with my phono preamp. Anybody else tried this? Thanks!
John
Crack, Reduction + Integration
Offline Adrian
Re: Using a SUT with a Reduction + Integration
« Reply #1 on: August 20, 2018, 11:20:12 pm »
I like my Rothwell MCL (w/ Ortofon Quintet Black through an Eros).
However, I'm sure there are others on this forum that can tell you how to build one, if that's what you're looking for.
Adrian C.
Rega RP6 w/Ortofon Quintet Black MC/Rothwell MCL Lundahl SUT/EROS/Submissive (3 output mod)/Mainline/Crack - Speedball/S.E.X. 2.1 - C4S/S.E.X. 3.0 - C4S/Paramounts - Blumenstein 2.2 Mini-Max w/DOF mod -Senn HD600/Viso HP50/Focal Elear.
« Reply #2 on: August 21, 2018, 04:11:33 am »
The SUT needs to be matched to the cartridge and not really the phono preamp.
« Reply #3 on: August 21, 2018, 05:39:43 am »
PB is right, and that includes making sure the nominal output of the cartridge gets stepped up to at least 3mV and preferably more like 5mV. So a .3mV LOMC needs at least 1:10 stepup ratio,  a .15mV cart would need at least a 1:20 ratio, etc.
« Reply #4 on: August 21, 2018, 06:00:02 am »
Some good reading and practical examples of what goes with what can be found here:
http://www.sowter.co.uk/phono-cartridge-transformers.php
For a large majority of cartridges, the Sowter 1990 is going to be an easy choice.
Offline audiomaniac
« Reply #5 on: August 21, 2018, 07:24:50 am »
Thanks all, I appreciate the information. I have considered stepping up ;) to the Eros. I was wondering more about how the Reduction "plays" with a step up, i.e. any issues with hum or other anomalies others may have experienced. I guess it depends more on the sum of the parts.
John
« Reply #6 on: August 21, 2018, 07:29:35 am »
Hum will depend on the SUT and what sources of magnetic radiation you have in the room.  If you currently have a 5mV cartridge and you get a 250mV MC cartridge and a 1:20 SUT, then the contribution of the Reduction to the noisefloor will be roughly identical and output voltage from the Reduction will be similar between both setups.
Offline adeep42
« Reply #7 on: August 21, 2018, 08:21:01 am »
Just a note. I use a SUT between my MC cartridge and an Eros. Works perfectly, no hum.
Crack with Speedball
Eros
VPI Prime
Ortofon Cadenza Bronze
Bob's Devices VPI SUT
Phoenix Eagle PSU & Tach
Cambridge 752BD
Apple Airport Express
PrimaLuna Prologue Pre-amp
PrimaLuna Prologue Amps(as mono-blocks)
Martin Logan Summit X's
Offline audiomaniac
« Reply #8 on: August 21, 2018, 09:28:22 am »
OK, so here's a question. I have a nice Garrott Optim FGS cartridge that I've enjoyed for years but I have the fever and want to move to a MC cartridge. Would it make more sense to build an Eros now with the ability to use my current cartidge and a HO MC cartridge down the road or invest in a SUT and a moderately priced MC cartridge now a stay with the Reduction?  ::)
John
« Reply #9 on: August 21, 2018, 12:42:51 pm »
The Eros will pair far, far better with your current cartridge than the Reduction does.  I'd run that cartridge till the cantilever falls off!
Offline audiomaniac
« Reply #10 on: August 21, 2018, 01:15:33 pm »
Yeah, I know. Hard to beat that Garrott. I sure wouldn't mind building the Eros. Bottlehead kits are great!
John
