May 22, 2019, 09:59:29 pm
Author Topic: Slight hiss sound from HD 800's  (Read 396 times)
Offline Jimb0
« on: June 28, 2018, 06:36:58 pm »
I'm using HD 800's for my Crackatwoa and getting a slight hiss. The hiss however gets louder as I raise the volume up. When I plugged the 800's into my Crack it sounded even louder. On the other hand my HD 650's are quiet at any volume level. I traded these HD 800's so they were used when I got them.
The hiss doesn't bother me much, more just wondering why I'm hearing it. Any ideas?
Re: Slight hiss sound from HD 800's
« Reply #1 on: June 29, 2018, 04:47:13 am »
Do you have anything plugged into the amps when you're performing this test?
« Reply #2 on: June 29, 2018, 06:14:12 am »
Sure, HD800s have a well documented slight treble peak compared to HD600s or 650s. That's going to emphasize any hiss coming in from your source. Suggest reading up about HD800s.
Offline Jimb0
« Reply #3 on: June 30, 2018, 01:57:12 pm »
Yes I had my Schiit Modi Multibit DAC plugged into both amps.
Thanks Doc, I'll surely read up on it. I did not know the treble peak would emphasize the hiss. I thought my headphones may have been damaged as I got them used. I will surely try a different source as well to see if that clears up the noise.
Offline Jimb0
« Reply #4 on: July 01, 2018, 01:44:45 pm »
Doc, you were absolutely right. The treble 6 hz peak did increase the noise I was getting from my computer. I tried the 800's on my laptop through my amp and everything sounded dead quiet! Phew, and I thought I had a damaged pair. Many thanks!
