May 25, 2019, 04:14:22 am
Author Topic: Troubleshooting Resistance Checks  (Read 1377 times)
Offline ksolis01
Re: Troubleshooting Resistance Checks
« Reply #30 on: June 06, 2018, 12:05:49 pm »
The voltage across the 2.49K resistor on the center C4S board above the 12AU7.  It should be well under 5V on both sides.
Did another check. The b side 59V value was actually due to remaining 6AQ5 tube being loose on one side so it is 54V. What should I check since the values are way off 5V?
« Reply #31 on: June 06, 2018, 01:02:56 pm »
I would suspect that the ground wire (or jumper) feeding that portion of the board is broken.
