May 25, 2019, 04:10:45 am
Author Topic: Transformer Secondary Test 3.5V instead of 3.3V on Terminal 12 and 13  (Read 234 times)
Offline Jimb0
Hi. I'm currently performing a secondary test on the transformer for terminal 12 and 13. The manual says its suppose to read 3.3V AC. I'm getting 3.4V then it goes up to 3.5V. I double checked the wiring and made sure it was for 120V outlet.
Is this normal?
« Last Edit: May 09, 2018, 10:54:27 am by Jimb0 »
Offline Jimb0
I checked the other measurements as well.
I'm also getting 3.5 on 11/14
6.6v on 9/15                 6.3v normal
168v on 20/19              161v normal
Offline Jimb0
N/m. I see that there is a +-10% next to each voltage. Doh!
You didn't post your measured AC mains voltage. It's probably a little higher than 120V. Small variations there will cause small variations on the secondary readings.
