May 25, 2019, 04:14:18 am
Author Topic: Clarification on the 10k uf cap mounting  (Read 337 times)
Offline ALL212
« on: January 05, 2018, 11:56:50 am »
Bottom of page 46 - 6.3 electrolytic into the outboard holes of Y and Y+ on the B side.
The stack of three holes furthest from the mounting hole (bB) is NOT what I use.  The single hole closest to the mounting hole is Y?  The y+ side has no such confusion.  The picture shows using the single hole on the Y.
I'm going with the picture but since it says outboard hole and Y only seems to have 1 hole I'm just checking.
THanks!
Aaron
Aaron Luebke
Re: Clarification on the 10k uf cap mounting
« Reply #1 on: January 05, 2018, 12:52:26 pm »
The stack of three holes by bB is simply the connections to bB.
The Y+ and Y- (it's a bit easier to see the "-" on the other side of the board) are their own set of holes, with one set designed to fit a small resistor (33K in this case) and the other a bit heftier to support a capacitor.
Offline ALL212
« Reply #2 on: January 05, 2018, 02:06:02 pm »
Thanks PB!  Much Appreciated.
Aaron
Aaron Luebke
