May 25, 2019, 04:10:06 am
Author Topic: Power Cord Heat Shrink  (Read 643 times)
Offline butchbass
« on: July 28, 2017, 11:37:52 am »
I want to redo the IEC end of my power cord and would like to know the pre-shrunk size of the heat shrink and where I can purchase it from. I do love the flexibility of this cord!
Butch Gross
Stereomour II/  Blumenstein Orcas, Dungenes/Schiit Bifrost Multibit/Amarra
Re: Power Cord Heat Shrink
« Reply #1 on: July 28, 2017, 11:45:07 am »
You can put a caliper or measuring tape on each end that you want the heashrink to cover.  The wall plug will be the bigger one, and you'll want to oversize the heatshrink just a tad so it slips over easily.  Now measure the diameter of the cord.  The heatshrink will have to shrink enough to fit the cord, so if the AC plug is 2" in diamter and the cord is 1" in diameter, a 2:1 ratio would barely work, but a 3:1 would really be the way to go (note that these are not the actual dimensions of the parts).
I always recommend using heatshrink with adhesive on the inside, as it makes for a very solid connection that takes vastly more time to fail than normal heatshrink.
The heatshrink that comes with our power cord kit has adhesive lining, so it will be quite a bit more work to remove it, especially from the tech flex sleeving.
