May 25, 2019, 04:14:12 am
Author Topic: 6P15P for Seductor?  (Read 702 times)
Offline Cary
6P15P for Seductor?
« on: April 25, 2017, 04:20:23 am »
Cab the 6P15P tube be used in the Seductor without modifications?
Cary
Offline Chris65
Re: 6P15P for Seductor?
« Reply #1 on: April 25, 2017, 02:56:37 pm »
The 6p15p is not a direct EL84/6BQ5 replacement, so without modifications, I doubt it.
6p14p is the Russian EL84 equivalent, as supplied by BH in some kits.
kevner21
« Reply #2 on: February 11, 2018, 01:25:32 pm »
I would be very surprised if you could not use 6p15pev in your seductor, very good tube !!!!!!!
« Reply #3 on: February 11, 2018, 03:12:21 pm »
They are sufficiently different that I would NOT recommend it. Seductor is direct coupled, and (unlike most Bottlehead amps) uses significant negative feedback. Both factors make it less stable in the face of changes. If you try it, and the amp blows up, I'll sympathize, but I'll still say "I told you so!"
